What is the simple way to bridge a 2 channel amp?
Max129
What is the simple way to bridge a 2 channel amp? I have two 15" subs in parallel, but now how do I bridge the amp into 1 channel? -- Max
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 1600
if the amp supports bridged mode, you should have directions for how to wire the subs in the amp's manual.
what make/model is the amplifier, and what is the impedance and number of coils for each sub?
us acoustis 150*2ch and sony 444 how to hook together and run 2 12" rockford punch
Username: Glasswolf
Post Number: 1753
you don't hook them together.
RTFM and see if they even support bridged mode first.
which RF subs are these? HE2? HX2?
you'd be best off just using the USAcoustics amp and trashing the sony.
