Infinity or kicker
dirty bird
wich would be the better buy kicker c10 or the infinity ref 1030w. considering there about the same price.
Username: Cenus
Hicksville, Ohio Usa
Post Number: 469
i don't know much about the infinity, but i own the kicker c12 and there pretty good subs for 50-60 bucks, just if you get the kickers and if you port the box make sure its around 35-40hz anything higher or lower make the subs sound like sh!t.
FlipityFlap
Why not get the RE 10, much better IMO. www.reaudio.com. I know that's not what you asked, but I wouldn't pick either of the ones you mentioned.
Username: Cenus
Post Number: 472
ya that would work to.
