Many people have been asking these Qs... answers here
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 866
xmax of the RE SE line- 18mm
xmax of the SX line- 21mm
NEW XXX information will not be revieled to the public until after it shows at SEMA nov 1st-4th.
he did tell me it is definetly still an SQL driver though.
... im excited lol... a dual 2 ohm XXX would be much easier than a MT with weird ohm loads for daily use.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10151
did he mention if the new XXX is still an CBL^2 motor?
Post Number: 868
no he did not. sorry glass
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 932
not certain if you meant xbl^2 or not glass (cbl^2=some funky derivative?) but as i understand it, the xxx will not be xbl^2. i can't get an affirmative on the actual topology though.
Username: Invain
Michigan United States
Post Number: 3662
I'm guessing he meant XBL^2, since the "C" key is right next to the "X" key.
Username: Jonathan_f
GA USA
Post Number: 4732
CBL^2-Crazy BL linearity. It's the next big thing, it's ok, though, I'm willing to buy your XXXs so you can step up to the next level in BL performance :-)
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10193
haha I was hoping they stayed with xbl^2 honestly..
ah well.
I bet you'll see some old XXX subs pop up when the new ones hit.. people upgrading.
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 993
I'm really looking forward to seeing if the new XXX will like a ported box. If its Qts is in the right range...i may be going to a 15" or 18" w/ 2 kx1200.1's :-)
if not, i'll just stick w/ SX's.
