Silver Member Username: TdbdadrummerPost Number: 165 Registered: Aug-05 | Cadence Beast B124 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=1924 Cerwin Vega V-MAX 12 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=1951 Diamond Audio D612D4 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2704 Eclipse Aluminum T4 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=1995 Image Dynamics IDQ http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2035 JL Audio 12W3 V2 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2898 Memphis 15-M3124D http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2128 Rockford Fosgate Punch Stage 3 12" http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2241 That's a list of subs in my amp's power output capability range, as well as my price range, considering they can all most likely be found on Ebay for about $150. The thing is, I want loud, tight, smooth, euphoric bass from the one I choose out of that list. Can someone tell me which will deliver to what I'm wanting? Thanks! |
Silver Member Username: Subzer0Richmond, KY USA Post Number: 800 Registered: May-05 | eclipse,IDQ are my choices.. |
Silver Member Username: UcfsaxmanOviedo/orlando, Fl Post Number: 127 Registered: May-05 | I would say the JL, eclipse or The IDQ. I am big fan of JL so I'm a little biased. |
Silver Member Username: TdbdadrummerPost Number: 167 Registered: Aug-05 | Ok, out of those, which is gonna pack more of a punch? And will ANY of those get louder/sound better, than my Volfenhags? |
Silver Member Username: Iufan4lifeulLouisville, Kentucky Post Number: 424 Registered: May-05 | the question SHOULD be which one of those is NOT better, in which case the answer is none. |
Silver Member Username: TdbdadrummerPost Number: 170 Registered: Aug-05 | LMFAO! Ok, you make a good point lol. But I want the one that gives me the best SQ at high levels! |
Gold Member Username: CarguyPost Number: 4250 Registered: Nov-04 | You need JL W7 in a HO box. It will give you SQ as well as SPL. Try and listen to one before buying any other box/sub. I'd like to cut open that HO box and see how it's designed. Somehow, it's making the sub sound 2x louder. |
Bronze Member Username: Robert_dMIA, FL USA Post Number: 13 Registered: Sep-05 | reaudio is another choice a 12" Se is 169$ - 600 rms made for SQ |
Silver Member Username: TdbdadrummerPost Number: 172 Registered: Aug-05 | Ummmm...I'll technically HAVE the money come January to buy a W7, but I still need other essentials like a good 4 channel amp, new h/o alternator, cap, and stuff of that nature. What about a couple of JL W6's? Are they any good? |
Silver Member Username: TdbdadrummerPost Number: 179 Registered: Aug-05 | Prolly will go with the Eclipse, Diamond, or Cerwin Vega. |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 1060 Registered: Aug-05 | go with the V-MAX, my buddy had two of them in a bandpass box, built specifically for the CV's, and WOW!, the loudest 2 10's in an explorer i have ever heard,very good SQ as well. you are going with one 12", or are you going to use the box that has your Volf's in it and (obviously) go with 2 12's? |
Silver Member Username: TdbdadrummerPost Number: 180 Registered: Aug-05 | Using the box I have, so 2 12's! |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 1066 Registered: Aug-05 | i would still go with the cv's. personal preference |
Bronze Member Username: ErikdagenerikLivermore, CA US Post Number: 43 Registered: Aug-05 | i have the diamond d4 but 10", its okay. im waiting for my box to come in so i can install my IDMax. Ill let u know how it goes! |
Silver Member Username: ChriskleinPost Number: 229 Registered: Aug-05 | The Diamond and the IDQ are the only subs on the list that i would ever buy. I owned the TDX's(D9's) and i was going to get IDQ's at one point as well, so they are my choices. I have also heard the alluminums and v-max's and i dont think they sound as good as the subs i voted for. |
Silver Member Username: TdbdadrummerPost Number: 184 Registered: Aug-05 | Hrmmmm...Ok...let's try this ONE LAST TIME. I want the sub from that list that will be loudest and sound the best out of all the others listed. |
Silver Member Username: ChriskleinPost Number: 234 Registered: Aug-05 | I would say that the Diamond and the IDQ have the best SQ of the ones listed. If i had to choose ONE of them i would ahve to say the Diamond. Diamond makes an all-around great product. |
Silver Member Username: TdbdadrummerPost Number: 190 Registered: Aug-05 | Hrmmm ok then. They aren't too badly priced either. Hopefully they get loud too... |
