15" kicker L7 vs. 15" Alpine Type R
Username: Brandonmoody
Rushville, Indiana United States
Post Number: 8
I am getting two new subs. I plan on buying 2 alpine 15" type r's. I also like the 15" kicker L7. Which one is better? Which one has better SQ and SPL. Which one should I go with? I like bass and good sound.
Username: Jron
Post Number: 107
squash the kicker and get an RE SX. the subs are more on the spl side but still sound good, and will outperform both the type r's and kickers. if you run two of any of these subs look into a ho alternator also. one Re SX should do you just fine, but still can handle 1000wrms. Basically man if you do not want to upgrade your alternator, one Type-R might work for you. If I were you Id go with the RE SX they perform well with 600 wrms, and once you upgrade your alternator, you can always slap more power on them. If you want more towards sql try the IDMAX and the Eclipse TI. You can also upgrade the amps once your alternator is taking care of with these also. good luck man.
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 904
between the 2 though, run with the r's. the l7 sounds like roast poo.
