Jl 500/1 gain and bass boost
madeupname
what do you think i should place them at? or is there a way to adjust them to the setting i desire?
Username: Basshead86
Ocala, FL USA
Post Number: 1102
you match the gain to the pre-out voltage of your HU. if you have 4v pre-outs, then the gain on your amp should be 4v.:-)
madeupname
how do i check that
Ocala, FL USA
Post Number: 1106
there should be markings above the gain dial on your amp, if not, it normally goes clockwise from (an example) 1v to 6v.
madeupmane
how would i use a volt meter to determine this?
