More ported Box Q's
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 649
ok i have my box layed out pretty much.. just a few concerns left.. its for a 15" type r. the older one, alpine didnt list any ported box ranges to stay in volume wise, but the sealed box volume range is 1.3 - 2.5 cu ft.. the one i have designed is 3.79 after sub and vent displacement anyone think this might be to big?.. also it is tuned to 34 hz.. is this to high for a 15?? just to give me perspective does anyone know the frequencies played in late night tip??
Username: Glasswolf
Wisteria, Lane USA
Post Number: 9922
what's the Qts of that sub?
in fact list me the TS specs ya have handy
that'll help
Username: Rzarector
Post Number: 651
TS: for 04' Alpin 15" dual 4 ohm Type r
impendance 4ohm + 4 ohm
Power Handling RMS/peak : 500w/1500
FS: ~ 1khz
Sens: 89 Db
Re: 4.0ohm + 4.0 ohm
Le: 1khz/20khz : 6.20mh/1.86mh
Fs: 24 hz
Vas: 98L
qms/qes/qts: 9.68/0.50/0.48
X max/x peak: 14.5/29mm
P-P: 68 MM
Hag/Hvc: 15.44 Mm
Sd: 754.77cm ^2
Username: Glasswolf
Wisteria, Lane USA
Post Number: 9942
I'd go more like 3 to 3.5cu ft, port tuned to 28Hz (6" ID port or slot vent)
they recommend sealed because the Qts is .48.. that's just below the cutoff for going sealed box.. it'll work ported, but it's more inclined to a sealed box due to suspension and damping factors of the driver.
Username: Rzarector
Post Number: 652
hmm.. im using this moreso for spl than sq for this sub.. since i already have an sql setup... the way i have it designed right now alows me to have an unbent port which is (15" x 2.5") 17" long btw with the port facing out the back towards the front of the car and the sub facing the back... on one hand i dont want the sub to bottom out ( as it did when a made a 4.somethin sealed box) but on the other i want to get as much spl out of it as a can.. and having an unbent port so i have herd helps out.. and i dont think the dimensions will fit the car properly if i want to keep the rear port design while shrinking the box
Username: Rzarector
Post Number: 656
bump^
Username: Jonathan_f
GA USA
Post Number: 4685
If you want SPL for a 15" sub, really you're going to look at 4 cu ft net and a tuning around 35hz. Any smaller in box size will limit the sub's SPL capabilities. Glasswolfs recommendation above would be great for SQL.
