How Dim is Dim
Username: Tdisanto
Post Number: 14
If your headlights dim for a quick moment thats ok right? But if they dim and take like a whole second or two to regain full brightness does this mean you should probably consider upgrading your charging system
Username: Illuminator
Post Number: 1593
That's hard to define...I wouldn't say the interval would be as important as how badly it dims (though obviously if they took a few seconds to come back on you're in trouble...).
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10138
best if you check voltages.. you don't want to see any dips below 12VDC
Username: Tdisanto
Post Number: 17
Where should i check the voltage across? At the battery terminals, the alternator, or at the amp?
Questions
Should check at the Alternator and at the amp. To see how much teh alternator pushing out and how much the amp is getting.
Ima consider getting a bigger battery for my Civic. Any reccomendations?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10179
at the amplifier or inside the car somewhere is sufficient.
you just want to see at or near the amp, how much voltage drops.
for the civic, optima, kinetik.. depends on your wallet.
