Remote wire where to connect
Username: Tatortot324
Post Number: 58
ok stupid question where do i connect the remote wire too??
Username: Xkawn
Post Number: 88
in your dash it's the blue and white wire and on your amp it should say remote. be sure to add a fuse close to the head unit. or for two amps split the wire (i use a butt connector) close to the head then two fuses after the split......
if u only have one amp ignore the post above and just connet where it says "remote" on the amp then run it to your dash with the blue and white wire
