Dumb question
I need an amp wiring kit for a JL 500/1 or a PG Xenon X600.1 I was wondering, What brand of wire and what gauge of wire should I get for the amps, Thanks
Username: Mrgalindo63
Chicago
I need help. I have a 4 channel 1200 watt Boss Ripper amp, and i have 2 DVC 4ohm Audiobahn SE in a sealed box. Will this work out fine? HElp me?
Username: Killerzracing71
Fredericksbutg, Virginia United states
Post Number: 8
bryan what are you asking?
as for anonymous a 4guage wire kit will work get a cheap one i spen 38dollars from summit racing products
http://store.summitracing.com/default.asp?Ntt=SWX-AK4&Ntk=KeywordSearch&DDS=1&se archinresults=false&N=0&target=egnsearch.asp&x=27&y=7
dont steal me thread man
Username: Homsardude
Post Number: 36
Anonymous: WalMart has awesome deals on wiring kits. They are probably not as nice as like a $75 wiring kit, but I'm willing to bet you'll never be able to tell the difference as long as you get a better RCA cable. I wouldn't use the included RCA cables.
Use 4 gauge wire.
Another option: I got a Phoenix Gold wiring kit myself and it worked out great. You can find them on eBay for about $30 shipped:
http://cgi.ebay.com/COMPLETE-4-GAUGE-AMPLIFIER-KIT-PHOENIX-DIGITAL_W0QQitemZ5802 726032QQcategoryZ71528QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Hope this helps!
Post Number: 40
Oops, just noticed that was the wrong link I put there. Oh well...that kit will work too :-)
Post Number: 21
75 dollars what?!! get the one i got 4 guage for 38 after shipping anywhere. but if you really want like jordan said get some better rca cables if you crazy about sound like that. Oh if you have never heard of summit it not no cheapo company just type in Greg Anderson and see what comes up.
if you dont check just look at this
everyone in pro stock runs about 6.9-6.85 @ 203mph in the 1/4mile. Greg managed to run 6.63 at 208mph
