FIrst time system help
I need help. I have a 4 channel 1200 watt Boss Ripper amp, and i have 2 DVC 4ohm Audiobahn SE in a sealed box. Will this work out fine? HElp me? My car is a 91 Buick Century
Username: Carguy
Post Number: 4117
That Boss amp is overrated. It won't produce anywhere close to 1200w.
Since you have 2 DVC 4ohm subs, yes it'll work with that amp in bridged mode. Wire each sub in parallel to get 2ohms and then in series for 4ohm total resistance.
Now bridge the amp so that you get 2 channels. Hook each VC on it's own channel.
Unless you can set the gain to be exact for each VC, don't use this amp.
Get a 2 channel or mono amp.
Username: Mrgalindo63
Chicago
will it run down my alternator?
