Amps
Username: Shagonwagon
Mom, Ontario Canada
I have a question what is the perfect size amp to run my 2 10 inch 450 watt each subwoofers ?? Would I also need to chage anything else in my car to power it I drive a ford taurus 1994 wagon
Username: James_g
TN
Post Number: 136
Are they 450w RMS or Max? Are they DVC or SVC? Are they 4 ohm, 2 ohm, 8 ohm?
Mom, Ontario Canada
they r 2 450 watt XS 10 aubwoofers with 3.6 ohms and im not sure whaT DVC or SVC means??
Username: Rovin
Trinidad & T...
Post Number: 220
Andrew , kindly read here www.bcae1.com 1st so u'll know more so that when others post (advice) to u - it'll make sense ....
Username: James_g
TN
Post Number: 141
Andrew,
Are those Sony subs? Do you have the exact model number?
SVC = Single Voice Coil
DVC = Dual Voice Coil
Mom, Ontario Canada
they are jensen subwoofers u can find them on www.jensen.com they are a single voice coil..srry for asking so many questions im totally new at this
Username: Rovin
Trinidad & T...
Post Number: 238
This'll be perfect for u - 1000wrms into 2ohms . When u connect 2) 4 ohm subs together = 2 ohm load .
can your budget afford this , $387 ?
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14926
Mom, Ontario Canada
I tihnk I can afford that amp ..can u still run the same subwoofers of a smaller amp?
Username: Rovin
Trinidad & T...
Post Number: 239
OMG Dude , i nearly made u literally blow up your subs ! .
I thought that its 450 W RMS now that i looked it up properly on Jenson's site , its ONLY 150 w RMS .
RMS is what u look at in supplying power NOT max .
Give me a few minutes & i'll pick something else for ya !
Username: Rovin
Trinidad & T...
Post Number: 240
Here are 4 great choices
www.discountsjungle.com - should be even cheaper there !
