What does this shyte mean?!
Username: Mrdark
Post Number: 79
http://www.precisionpower.net/ppipdfs/signpro/deq230.pdf
Thumbnail #8, look at the warning about using high level speaker outputs?! Will my Alpine deck (which is a 60wx4 ch HU) work, or do I need a low level adapter?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10102
the DEQ230 is made to be used with RCA level inputs only.
it goes between the head unit and amplifiers.
use a deck that has line level pre-outs with that unit if you want good results.
you shouldn't be using any head unit power with a 1/3 octave EQ in place.
Username: Mrdark
Post Number: 80
Thanks Glass, but what you're telling me is that any HU with RCA outputs will work with no problems?
My Alpine has a total of five RCA outputs, 2 front 2 rear and a subwoofer...
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10113
that'll work fine.
if I recall, the deq230 has two inputs and four outputs anyway
Username: Mrdark
Post Number: 81
Thanks Glass!
