Diamond Audio amps?!
Username: 99redbird
VA U.S.
what do you guys think about diamond audio amps? i just recently checked into these and decided to get one. i bought the D5 300.4 4-channel amp. anybody know if this is a decent amp or not?! thanks!
Username: Kd7nfr
Montpelier, ID United States
Post Number: 734
Diamond amps are pretty good. IMO are as good, if not better than JL Audio amps.
Username: James_g
TN
Post Number: 114
Diamond Audio is a high-end brand. I went with their subs, and thought about their amps. I looked elsewhere for my amps because of my budget.
I don't know the specs on that particular amp, but I'd say you did good. Glad to see you didn't purchase Legacy, Pyramid, Profile, MA, etc., then ask about it. LOL.
Username: Rovin
Trinidad & T...
Post Number: 171
I like that last line from James .
What subs u gonna use with it BTW Brandon ?
Username: Rovin
Trinidad & T...
Post Number: 175
OOPS - now seeing its a 4 channel amp , my bad .
Well then the ? is - what speakers/components u gonna use ?
Username: 99redbird
VA U.S.
Post Number: 8
I will be using the Diamond amp to power 4 Infinity Kappa 6.5's. I already have one set of the Infinity's and I am satisfied with how they sound, however they are lacking on mid-bass. I will probably go ahead and buy the second set, unless you guys have any suggestions on a better set for around the same price?! thanks!
Username: 99redbird
VA U.S.
Post Number: 9
I have 2 Rockford Fosgate P3's (12") and I just bought a Rockford amp to power them. It's the 601s model from 2003 I believe...rated @ 1800 watts peak. Anybody have any input on that amp?
Username: 99redbird
VA U.S.
Post Number: 12
Nobody has any opinions on the fosgate 601S??
