Bumper Rattle.......Need Help!
Username: Necro1990
Saint John, New Brunswick Canada
i got about 95% of my trunk rattle to stop, but now the only thing basically u can hear is my bumper rattling, i kno they are only being held on my clips but what could i do to HELP stop the rattle?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 9636
remove the entire bumper clip and line the plastic bumper cover clip with foam.. dynamat or spray type.
something to prevent the vibrating.
Username: Necro1990
ok thanks man ill give er a try
My HOLE TRUNK RATTLES how do i stop that?? My 2 12's in my Civic seem as if my trunk is going to pop off.
