Im screwed
i lost a screw and square plate on an amp.
how can i replace it?
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 810
Circuit City or Best Buy should have replacements.
thats a 45 minute drive i need another suggestion
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 815
Solder the wire to the amp.
thats too messy.. i think im just gonna have to pay for an over priced terminal strip and steal one of the screws off of that
Username: Legacyaudio
Post Number: 158
you must suck a.ss at soldering becasue soldering is one of the least if not the least messy type of welding
im too lazy to clean it up with the desoldering braid
and that doesnt fix it for the next person to own the amp
Username: Kd7nfr
Montpelier, ID United States
Post Number: 736
"you must suck a.ss at soldering becasue soldering is one of the least if not the least messy type of welding"
Welding? ROFL! And you should be able to solder that really easily... I dunno, maybe just me, I solder on circuit boards regularly, but that shouldn't be bad at all. Maybe drill it out and put a bolt in it? Or find a new bolt that fits the hole?
Post Number: 165
jake, you do realize that soldering is a type of welding right- so what is so funny???
soldering is better than a screw who carres about the next person
..just a different way of duct taping
Username: Kd7nfr
Post Number: 743
It is a type of welding... but it was just funny to consider it that...
(I'm used to 200+ amps)
