Can I ground to the factory tie downs?
Username: Fatz
Bossier City, LA USA
Post Number: 18
In a 97 Jimmy, can I ground the amp to the factory tie downs in the back? aren't these bolted down to the frame/body?'
Awaiting your response.
rideredder
should be alright just grind the paint off and bolt it down there if that doesn't work find another spot.
Username: Fatz
Post Number: 19
Well, if it doesn't work, will I blow my amp?
rideredder
no
