Weird Noise
KMKRoyalKing
I was moving my amp for my 6x8's when I touched the rca cables it made all my speakers make a high squeeling sound. Now everytime I put pressure on the rca's where it plugs in it does this. Is it just because the plugins are loose or what?
Username: Kd7nfr
Montpelier, ID United States
Post Number: 732
Just don't touch the RCA's...
Username: Glasswolf
Wisteria, Lane USA
Post Number: 9531
most likely you damaged the amplifier when you did that.
this is why I keep telling people not to screw around with wiring when the system is powered!
Username: Kd7nfr
Post Number: 733
Yea, and be careful when you're adjusting. Make sure EVERYTHING is PERFECT before you first power it up... And after you get it mounted, wired, and adjusted, leave it the hell alone! Heh.
