2 questions
Username: 2loud4u
Boca Raton, FL U.S
Post Number: 20
Hey I know I have asked this question before on a previous post but i have to know if there is a company that makes a bass knob with two cords, so i can turn the bass up/down on both amps at 1 time. Thanks.
Also I wanted to know how to wire two amps to 1 sub. If someone could give me a diagram it would really be appreciated. Thanks.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 9535
first, you'd need to use a pre-amp or crossover with a remote level control and run both amplifiers from that device, so the device controls both amps at once.
second, you need a sub with dual or duad coils, and you'd wire one amplifier to each coil or pair of coils, and use a scope to balance the gain settings for both amplifiers to ensure they put out the same power so you don't damage the sub.
Username: 2loud4u
Boca Raton, FL U.S
Post Number: 23
Thanks Alot Glass.
