Odd question
Username: Supraspyder420
Sammamish, Wa U.S.
Post Number: 138
Well im putting speakers in my boat (eclipse SP8964) and they have the polypropylene cone and santoprene surround. Now ive choosen these over amrine speakers because marine speakers sound liek crap. SO my question is, can i spray them with a fabric/carpet protector? I know this sounds weird but it is a very thin application and wont peel, crack, or anything, and isnt hard at all. so the santoprene surround can move freely.
Any thoughts are appreciated.
Sammamish, Wa U.S.
Post Number: 139
Oh and im asking because i want to find a way to make them a little more water resistant. But thats obvious
what about that spray for distributor caps to keep them water tight?
or any silicone spray for that matter
Sammamish, Wa U.S.
Post Number: 140
anyone?
Username: Scubasteve
Annapolis, MD
Post Number: 466
If they're exposed to water or extreme humidity, be prepared to replace them every 6 months or so, maybe longer if you're lucky. The home speakers I put on my boat have been fine for about 4 years now, but they're also in a cabin with de-humidifiers...As for spraying them with waterproofing, I can't say whether or not that will corrode the surround. Look on the package and see what the active agent is.
