Need help tuning amp
Username: Glocknesmonstr
Largo, Fl Usa
Post Number: 15
Ok dont bash me but I have an audiobahn a8002t amp and an audiobahn 1506t sub in a ported box. What should i set every thing at. like gain,subsonic filter,frequency. Plz let me know some one with experince would be great like glasswolf.
Largo, Fl Usa
Post Number: 16
Oh for got this dont know if it maters. but running each voice coil to each channel. with a v split rca to make it mono.
Username: Sploosh56
Ohio
Post Number: 839
Start by turning your amp gain all the way down. Then go to your cd player and turn the volume about 3/4 the way up. Then go back to your amp and turn the gain up till you hear distortionand when you do turn the gain down jsut slightly then. As for where your sub should be crossed over at I'd cross it over at about 60 hz. Set your subsonic filter slightly below the tuning frequency of your box. Or you could jsut set it at 25 hz.
Largo, Fl Usa
Post Number: 17
thx bro.
