Need Speaker Wire Guidence Please
Norm Macdonald as Bob Dole
Can anyone explain to me, or send me a link to somewhere that can explain what size speaker wire to use in what applications? Does it matter what gauge wire I use from my sub to my amp? For example what gauge would I use for 400w rms? Basically if someone could send me a scale of the power handling of the different gauges and when to use them I would be forever grateful.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 1670
speaker wire isn't that vital for size. Not like power wire.
for speakers, here's a good rule of thumb:
for subs, use14ga up to 10ga, depending on how fancy you want it to look.
fo rcomponents, 18ga-16ga is fine.
Thank you. I really appreciate your response.
Username: Its_bacon12
Post Number: 355
hehe i use 12 awg for everything in my car - components to subs...that way i'll almost never have any resistance problems with the components and as long as i stay under like 1500w rms for my sub, ill be fine there
