Need Help With Monsoon Speaker Replacement
Username: Face
Long Island, NY USA
I blew out both my rear 6x9's subwoofers on my 99 Buick Regal. The problem is the 6x9's are 2ohm, and I can't find a replacement other than stock. Any recommendations other than placing an enclosure in my trunk with 2 2ohm subs?
Thanks!
Alec Beaton
You can use some 4 ohm aftermarket speakers with the stock amplifier. I think on the regal they used DVC speakers on the back deck. If you used some 4 ohm speakers, it'll souuldn't overload the stock amplifier. Hope this helps.
