Capacitor help
Username: Smallville
Sandy, Utah Utah
Post Number: 34
i have a capacitor audiobahn brand and it has two wires on top of my capacitor and i dont know what slot to hook it up in in my amp?
Username: Xxcodytxx1
Post Number: 22
You cut the power and ground wires from the amplifier, and then run them through the capacitor and then back out of the capicitor
Username: Glasswolf
Wisteria, Lane USA
Post Number: 9234
STFW or RTFM
GemaireOcala
Set it down, step back and don't guess! Take it to a dealer. It may blow up if incorrect!
Username: Ihaveasystem2
Post Number: 70
does it have a + or - on it if so you want to ground your cap to a different part of your chassy then where your amp is grounded and run the main power through the cap before you run it to a d-block or a amp
