2 amplifiers
Username: Xxcodytxx1
Post Number: 17
I just got a second amp, and i want to hook it up to capacitor/distribution block, there is 3 negative feeds, and 3 positive. Im thinking 2 positive from the amp, then 1 postivie to the battery(fused). Then 2 negative to the cap, and one to the chassy. Also I have a 4 gauge wire to the engine currently, If i use 4 gauge wire to the cap from the amps, will that disrupt electron flow? Should i use 8 gauge from the amp to the cap or can i use 4?
