2000 Hyundai accent, factory cd player shows err 6
Username: Lisastuge
What does err 6 mean and how can I fix it?
Username: Carguy
Post Number: 4819
Is your factory cd player Clarion? If not, what brand is it?
Username: Lisastuge
It's factory.
Username: Carguy
Post Number: 4820
When do you get the err 6? All the time or on certain cds?
I think err 6 means disc error.
Username: Lisastuge
Any disc. All the time. I can put a disc in and about a max of 10 seconds passes before the disc is ejected and the display reads er 6.
Username: Carguy
Post Number: 4827
It's either, the cd lens are dirty or damaged. If you have a cd cleaner, try it. If that doesn't do anything, replace the unit. Not worth getting fixed since they'll charge 2x - 3x more than getting a new unit.
