Need good subs
Username: Pootie69
well, what kind of subs do you recommend that make crazy bass and are cheap and dependable?
Username: Jaackdeth
United States
Post Number: 526
Kicker CVR's would be a good choice if your budget is low!
What is Cheap?
Username: Jaackdeth
United States
Post Number: 527
Also you should post this in the Sub catagory!
Username: Aud
Post Number: 8
try audiobahn.....look on ebay they have real good deals for audiobahn subs....... i personally have 2 AW120T 12" (500rms each) speakers and paid like 125 after shipping for both of them
Username: James_g
TN
Post Number: 36
Just remember that you get what you pay for. The Comp VRs can be had for about the same price as those Audiobahn subs. Alpine Type Rs can also be had fairly cheap on eBay. Lots of people brag about them on various car audio forums. The 12s are also 500w RMS.
Username: Suleman36
Maryland U.S.A.
Post Number: 1970
Check out Resonant Engineering RE series subs or the SE series.
www.reaudio.com
