Panasonic CQ-VD7001U - DVD mp3 question...
I was looking into getting the Panasonic CQ-VD7001U and had a question about the mp3 playback capabilities. From all the specs I can find it simply says that it can play mp3 and wma encoded discs but it doesn't specify CD or DVD. Basically what I want to know is if I could burn mp3 files/folders onto a DVD and play them in the CQ? Obviously since the DVD holds more info I could fit more albums onto 1 disc.
Thanks.
Username: Clethal70
Post Number: 19
Theres some options i can give you for that. Yes you should be able to burn Mp3's to a dvd and it should play. I have a Alpine IVA-D300 and can do it only thing it only reads half the folders on the dvd. Now theres a program out there called dvd audio creator which I love thing is it may take 8hr depending on your computer to convert the files and burn it to a dvd. http://www.audio-dvd-creator.com/ You can put up to about 38 music cds onto a dvd with all song tiles and artist.
