Whats the diff. between w6 and the w6v2
what is the difference between the w6 and the w6v2.....which one is a better sub
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 1628
the W6v2 is a much better sub. totally redesigned.. better sound quality.
Username: Bdb_86
Bemidji, MN Usa
Post Number: 66
glasswolf do you know what the difference is that makes it better im curious
Norm Macdonald as Bob Dole
100 more watts RMS - Good enough for me.
Its coneless.
Tim L.
the main difference between the two subs is their technology..
the v2's incorporated/use some of the innovative technology JL introduced with the W7..
the elevated frame cooling technology and other things added for the v2 helped make heat dissipation better so the voice coils could handle more power.. the new W-cone added, floating cone attachment technology, and things like motor technology help to make the sub built and perform/sound better..
