Vented Sub Boxes
Username: Rollinondubs
I got a pair of DVC Kicker CVR12s in a sealed meduim size box (1.25 cubic feet per sub) What size round ports do I need to buy to make this a vented box for deep loud bass?
Username: Thespotlight
Amarillo, TX USA
Post Number: 45
You will need a bigger box if you want it to be vented.
Sorry measued wrong, its a little over 2 cubic feet per sub
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 1627
2cu ft per sub is great.
ports should be 4" inner diameter.
length, you'll need to get me the actual box volume per sub, minus the displacement of the actual sub(s)
then I can figure the port lengths.
we'll tune the box for about 34Hz
