What would sound better???L712 or Brahma 10or other???
i just wanna know what would be better???
i have a jbl bp600.1 amp, i wana get either a L712, brahma 10, or 2 compvr 10's...
i would put the L7 or the brama in a vented box and the compvr's in .74 cu ft sealed ones...what knida SPL would each give me????
and would 600 watts even touch the ability of the brahma????
Username: Dan3
Post Number: 14
brahma and the compvr's will have the best SQ, the l7 will have the best SPL, go with what you'd like, and if you'd want SQ, i'd personally go with 2 subs rather than 1 and so in your setup that would be the compvr's
Username: Its_bacon12
Post Number: 267
i think the brahma would have best SPL and SQ..i would definately go with the 10 inch brahma
28mm 1 way XMAX on a 10 inch sub is absolutely insane and thats what the brahma can give you
http://www.adireaudio.com/Files/20br10rollin.mpeg
theres a little 10 inch brahma pounding away, just a little bit to show you what those little buggers can do
i really want a pair of brahmas to put under the seat of my ext. cab truck w/ .74 cuft each, but i dont know if a pair of JBL BP 600.1 amps would even touch their ability....
it looks like each one could handle a KX1200.1!!!
i have one BP600.1 and i would buy another if i get the Brahmas....would they pound w/ 600 watts each????? or would that be a waste of a good sub??? and how much louder would the brahmas be than my L712 in the sealed box w/ one BP600.1 on it???
Username: 1_kicker_fan
Lipan, Texas America
Post Number: 7
go with which every u like sq or spl.
Tim L.
wait.. you already HAVE an L7?
600 watts to a brahma would be fine.. it'd still hit hard, etc.. and the brahmas would have the best Sq out of those 3.. would it touch the POTENTIAL PERFORMANCE ABILITY of the sub? no.. but i'm sure you would be satisfied..
Post Number: 338
if you have it in a large sealed box 600w may be all the brahma needs to reach its limits
remember tim, its all in the box...
look at the adire power handling page
http://adireaudio.com/mobile_audio/drivers/brahma_power_handling.htm
it shows you that with a .87 cubic foot sealed box, you only need 700 watts to reach the limits of the brahma 10
and keep in mind that that 10 inch sub has 28mm xmax 1 way and thats EXTREMELY huge throw for a 10 inch sub so you will get alot more out of this 10 than almost any other around
Post Number: 339
heres a link to a 10 inch brahma poudnign away
heres one to show you what 4 15" brahmas can do
http://www.adireaudio.com/Files/ScottieJBrahmasBreakingDoors.wmv
Tim L.
i like to think of it as 50% box/set up, 30% driver, 20% other stuff..
Post Number: 345
i say its 50% box, 35% amp, 10% driver, 5% everything else
hehehe
Username: Southernrebel
Louisiana USA
Post Number: 10
well, heres the problem...it has to go under the seat of my truck...
have any of you seen the kind of box that i'm talking about???
it looks like this...
http://www.proboxrocks.com/chevy/88-98extended.shtml
i dont think the brahmas will fit!!
but does anyone know what good subs will???
