Amp trouble
Username: Traxxasx
Las vegas, Nv Usa
Ok, guys i need some help. I have a rockford fosgate 600watt amp. I had it hooked up in my car working all fine, i washed my car and as i was driving i hit a bump and i guess the amp moved, and there was water around it. So my amp stopped working. First i checked all the fuses and the one on my +(from batt) was blown. So i change it , and turn the car on and that one blew again. So i tried a couple of times, same thing blown. So i checked all the wires (see if they were grounding out) there good. So i tried a higher fuse on the + wire and the amp fuse blew. So i took the amp out opend it and looked at every littel electronic thing inside, every thing seemed fine, so i waited a day to let it dry is there was any water in it, and the fuses kept blowin, so i dunno what could be wrong, and any help would be great. (thanks)
