Are subs fixable...??
Greggs
i have a P3 rockford sub that is rattling and i was wondering if i could get it fixed??? if so where might be a place to get it done at?
Username: Hurleyblink
Post Number: 109
Well whats wrong with it? if its like a hole/tear then yes.
Greggs
i think the coil is messed or it's blown??
Post Number: 111
Uhmm, i would just buy another 1 no point in getting it fixed... i mean u can get those subs for $60 on ebay whats the point of having the chance of a $20 - 30 fix going wrong. if its blown it will make a scratchy noise when you push down on the center of the cone
Greggs
show me where i can get it for 60 dollars on ebay...
Post Number: 112
http://cgi.ebay.com/ROCKFORD-FOSGATE-PUNCH-P3-12-500W-CAR-SUBWOOFER_W0QQitemZ579 4668042QQcategoryZ39779QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
