Quick Question
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 8
I have never heard any RE XXX's or any JL 1000/1 (I Live in Alabama), but would it be overkill to have 2 12' Re XXX" with 2 JL 1000/1, would the subs be getting enough power I think they are rated at 1600 rms. If not what are some amps that would push them nice ($500 budget)
Username: Iowahawks19
Post Number: 356
not even close, you would be underpowering one of them(if they're 1600w rms each)
your better off getting 2 amps, and running each amp to each sub, but with that kind of budget it will have to be hifonics or somthing
Post Number: 357
you know what, don't even consider hifonics with nice a@@ subs like those, but as far as underpowering yes, you need 3200w rms, i hope you have a alt. upgrade and a differnt battery in your car, thats some serious wattag
ask around, im not good with amps over 2000 watts, i don't know of many
Post Number: 15
thanx
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8845
the XXX would work with a 1000/1 depending on the enclosure type you choose. If you go ported, that'd work fairly well.
