Is this any good?
http://www.crutchfield.com/S-j4KEzVWLxth/cgi-bin/ProdView.asp?g=530&I=142FDMUS05
Username: Ffxdevilarms
Dubuque, Iowa United States
Post Number: 742
NO. That is a very BAD sub. I would not even take it for free man. Please do yourself a favor and do not waste your money. There are plenty of budget subs out there and that is not one of them.
Username: 78elcaminoman
Dallas, Texas United States
Post Number: 36
yaif u not a big time bass person
Username: Geekbike
Post Number: 351
If you can afford a 2005+ Mustang, I'd imagine you could afford slightly better equipment. But otherwise, call Crutchfield and find out how much airspace is in the enclosure. From that, buy the unloaded version (without the subwoofer) and find a 12" subwoofer that will fit in that enclosure. Or post here and someone can help you out.
Otherwise, go to a local car audio shop and have them price out a custom fibreglass enclosure and subwoofer. It might cost a bit more, but it will be well worth it.
Don't buy the one you suggested. You will regret it.
Post Number: 743
it is not good at all. Not even if you only wanted a "little" bass. Antonio, i know you are new and all, but please do not word stuff that way. I mgith just think that it is a good sub for giving a little bass when actuallity it isnt even worth the cost for the little bit that it might put out.
Post Number: 744
I meant "he might" instead of "I might" It is LATE and i think it is time for me to go to sleep. Have a good night guyes
So the box is OK right? Any good suggestions to what sub I should put in there? I have a 2000 watt amp by the way.
Also if I may ask, how does everyone know it's a piece of crap?
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 59
B/c scosche is a no name brand for speakers they're wiring is wal-mart brand and would be better than that sub.
Post Number: 746
I wouldnt even buy their wiring to tell the truth. Chances are anything that you find at Wal-mart is junk. The box is prob allright, but if you can build one if would be much better.
