Which are Best: Kicker Comp vr, Infinity Kappa Perfect 10, or Alpine SWR-1042D
Username: Cnc837
Norman, OK USA
Post Number: 11
Which of these subs are the best and why? If I am not mistaken, the Kickers are most expensive, then the Infinity, then Alpine.
Username: Dominirica012
Charlotte, North Carolina US
Post Number: 616
depends what your looking for..they are all cheap(pricewise) but their all good
SPL
Kicker>Alpine>Infinity
SQ
Infinity>Alpine>Kicker
as you can see the infinity is the best sounding sub, the kicker is the loudest and the alpine is the in between one
Username: Cenus
Hicksville, Ohio Usa
Post Number: 324
well if it was me i'd take the kicker but thats what i like, quick shot has them in the right order for spl and sq but listen to all them for yourself then decide, but were are u getting ur subs at because every i've looked the kicker is cheaper than the alpine.
Username: Iowahawks19
Post Number: 329
i would also go kicker
Username: Infinity_addict
Santa Rosa, California USA
Post Number: 42
SPL is only fun for so long.
Username: Dtribe
Post Number: 71
^he has a point
I used to be all bout some spl
and now im like WHutever that loudness all sounds the same and i want sq
Post Number: 330
yea but the kicker cvr actually dosen't have bad sq, it's pretty good imo
Username: Iufan4lifeul
Louisville, Kentucky
Post Number: 273
Can't go wrong with Alpine... I mean, that provides you a good mix.
