SPL and SQ
Username: Awdturbo_dsm21
Im looking for a new sub set up and im looking for a sub with a good SQ but i still want it to have good SPL some suggestions would be great and please tell me what amp you would run the sub with looking for something kinda high-end.
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 56
JL Audio W6v2, W7 or a W3v2. As far as amps go depends on how many subs and which sub. But JL Audio makes good amps so does Rockford Fosgate JBL, Orion and Zapco to name a few.
Username: Scubasteve
Annapolis, MD
Post Number: 274
JL is good, also IDMAX, Adire brahma, RE XXX, digital designs, Eclipse Ti to name a few more...whats your price range?
Username: Subfanatic
Ky
Post Number: 4626
ucfsaxman, dude you have an obbsessions with jl? lol.
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 57
Your exactly right Sub lol. I just bought 3 Jl audio 12 w3v2's and the XR Components! I'm siked.
id want to keep the sub and amp under $2000 and i dont need alot becuase the stuff is going in a hatchback.
Username: Modder05
Brooklyn, Oh
Check out the Soundstream Van Gogh series of subs and amps, great SQ and SPL under 2000.00 and great quality
Username: Supraspyder420
Sammamish, Wa U.S.
Post Number: 89
i have a soundstream van gogh (VGA600.2) and a IDMAX12 D2 V.3 and it sounds awsome. I highly recommend that set-up. ALthough if you get the van gogh and the IDMAX then id get the VGA800.2. IT has excelent SQ and very good SPL (more then enough for a hatchback).
Sammamish, Wa U.S.
Post Number: 90
both those wouldnt be over $650 also.
alright thanks for the help
is the VGA800.2.IT is the amp you would recomend for One IDMAX 12 d2 V.3
what sub would your use to run a RE XXX 12inch
