One quick and easy question...
Username: Kdkd2020
Post Number: 22
I was going to get two 12" audiobahn 400w RMS a sub... but now i am downgrading and getting two 10" 300wRMS a sub.. i am still going to use the audiobahn A8000T mono amp.. will my system still get the same low bass and bump with the tens?
Username: Jaackdeth
United States
Post Number: 206
The 10's will give you a tighter bass then the 12's, also most systems standard try and run 12's or a single 12 inch, because they are universal! The 12's would have MORE volume then the 10's
Username: Kdkd2020
Post Number: 23
Alright.. but if i go with the tens, will it still sound loud and hard?
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 631
You couldn't compare because the 12"s would take more power. I had some Audiobahns a few years back, and they are crap, the subs anyways. How much do you have to spend?
Username: Kdkd2020
Post Number: 24
I have about 500 to spend.. i already have the deck.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 642
Look into an Image Dynamics IDMAX, or possibly a Alpine Type R or two.
The IDMAX is 750 watts rms I believe, and the Type R's are 500 watts RMS.
Both of these would be a better choice than Audiobahn.
Username: Dominirica012
Charlotte, North Carolina US
Post Number: 417
you could also get a 12" or 15" XXX and call ti a day
Post Number: 418
o sh!t forget about that^ your gonna use that Bahn amp...you shouldnt be allowed to power an IDMAX with an audiobahn amp thats disrespectful lol,,,just get you some Type Rs and youll be fine
