Need Amp Help!!
New Guy 12
I've been searching for the right amp for 1 Alpine SWR-1042d sub. I found the Sony XM-D6000GTX. I need someone to teel me if this is a good setup before I buy it.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5771404472&category=18797 %26
Should I buy it??
Username: Thrushdtd
New York
Post Number: 213
NOOOOO!! how much do you want to spend?
New Guy 12
I don't want to spend that much. What about the Sony XM-SD61X???
Username: Thrushdtd
New York
Post Number: 217
dont get sony. I thougt you were going with the jbl 600.1 that is a real amplifier or even a good mtx model. I just posted a bunch of amps that would work good in your other thread i think.
New Guy 12
Whats wrong with this amp??? It looks like a great fit to me.
Username: Thrushdtd
New York
Post Number: 220
thier crappy amps compairatively for the price, thats whats wrong with them.
Username: Thrushdtd
New York
Post Number: 222
i got an amp that puts out a quality 1200rms @ 12.4 volts for less than that/
Username: Perrydog
Flint, Michigan USA
Post Number: 121
DONT BUY THAT AMP, you are payin way way way to much for an amp that has 300 watts rms and only 800 max, and honestly that amp probly dont even push that much, sony is very very very low quality amp's they put big numbers on the box to suck people in but there stuff dont preform
