Infinity 1230W's
Username: Richierch
Post Number: 93
i have two 12" 1230W's and i was thinking of making them black instead of silver by painting them or something, has anyone ever done this or have a site that shows stuff like it
thanks
Username: Richierch
Post Number: 94
also does anyone know where i can get good grilles
slim89
i like my 1230's the way they are, i put spinner grills over them, then i put blue lights behind the spinners and they shine on the subs. its so frickin sweet, why do u wanna paint ur subs anyway? what will the paint weigh, enough to make the subs heavy enough that they wont sound as good?
Username: Richierch
Post Number: 95
i dunno it was just a thought
i then remembered grilles and saw these on autozone.com
http://autozone.com/servlet/UiBroker?UseCase=C001&UserAction=performMoreDetail&P arameters=TRUE%7C%7ESpeaker+Rings%7C%7ENONE%7C%7ERedline++++++++++++++++++++++++ +++++12%22+Red+Neon+Speaker+Ring%7C%7ENONE%7C%7EFALSE%7C%7EFALSE%7C%7E341365%7C% 7E1369%7C%7E2575%7C%7ENONE%7C%7E%2459.99%7C%7ENONE%7C%7ENONE%7C%7ENONE%7C%7ENONE %7C%7E2.4%7C%7ENONE%7C%7EV%7C%7EQUE%7C%7Etrue
i want to get grilles but i can find a site with just generic grilles all i can find is audiobahn and kicker grilles...i wish that made infinity grilles...and did u get the scoshe grills
do you have a pic of your subs
slim89
i can get a pic.. yea they're the scoshe spinners.. u hook em up to ur amp and a motor spins them but i did a bit more and added lights, switch and stuff like that.
slim89
i thought they would rattle but they dont
Username: Tbolt
Collipark, GA
Post Number: 184
Paint ur subs, maybe if it's spray paint. Then you could paint the whole sub, and leave the infinity logo silver. Do it at your own risk.
Username: Richierch
Post Number: 97
ive decided not to paint but i am going to get lights and grills for them...i cant find grilles anywhere, anyone know where i can get them
Username: Richierch
Post Number: 100
no one knows of any good sites for grilles...i have looked all over google
