Ports
Does it matter where a port is on a box? Should it be below the sub, in a corner or does it even matter? Also, are round ports better than square vents and which is easier to build and work with (all the math involved)
Username: Tbolt
Collipark, GA
Post Number: 160
1.No it doesn't matter where the port is.
2.I like sqaure ports better than round ports because its easier to build and tune.
Username: 54danny54
Post Number: 653
if u think about it round are easier 2 build but square is easier 2 tune lol...easier 2 build because of pvc lmao
Username: Audiobass10
Cape Coral, FL United States
Post Number: 77
"1.No it doesn't matter where the port is."
Wrong. Port location can be a large factor in SPL.
Username: Tbolt
Collipark, GA
Post Number: 163
So whats the best location for the port.
Username: Alpineuser
Winchester, TN
Post Number: 690
for best results it is better to have the port on the same plane as the speaker, and round ports tend to give you a more linear sound.
Winchester, TN
Post Number: 691
also round ports take up less volume in a box then a slot port will, but the slot will help reduce port whistle.
Post Number: 78
"for best results it is better to have the port on the same plane as the speaker, and round ports tend to give you a more linear sound."
Not always. It depends on your application.
Username: Redskin
LondonEngland
Post Number: 157
"for best results it is better to have the port on the same plane as the speaker"
Tell that to everyone running CRX type boxes.
"round ports take up less volume in a box then a slot port will, but the slot will help reduce port whistle."
All things being equal( port area and tuning) then they both have the same volume. Having enough port area is what stops whistle.
