Suggestions PLZ!!!
Username: Singhsane
Scarborough, Toronto Canada
Post Number: 44
alrite im about ready to purchase a new system and im thinking bout going with.... 2 SX12's with 2 BX1605D's....hows that so far??...also i was wondering wat type of wiring i would need and how big of an alt. i would need to go with??..also would i need a red/yellow top battery??
Username: Singhsane
Post Number: 45
sorry another thing should i get the box made out of 3/4' mdf or 1' ???
Username: Letto
Milwaukee, WI
Post Number: 74
3/4" is usually sufficient, maybe 1" on the face, but 3/4" would prolly work fine.
If you're thinking about upgrading your alt, don't go lower than 200Amps, wouldn't even be worth the money you're spending on the upgrade otherwise.
Username: Taylor17
Kopperl, Texas
Post Number: 2510
Yup... all good points.
Sounds good. I like the SX's... good subs.
Username: Singhsane
Post Number: 46
any ideas on how much a 200Amp alt. will go for?? and wat type of wirring would i need?? any need for red/yellow top batteries??...thnx for ur suggestions
Username: Taylor17
Kopperl, Texas
Post Number: 2519
I think its all ways a good idea to get a good battery. I'd go with a yellow top, and the price is hard to say...
look at www.4alterstart.com just for ideas.
