Silver Member Username: Rob315Cuse, NY U.S. Post Number: 486 Registered: Jan-05 | anyone know where i can find the air space needed for them?...or better yet box dimensions for a ported box? |
Bronze Member Username: Audiobass10Cape Coral, FL United States Post Number: 48 Registered: Jul-05 | How many subs? What size subs? What are u looking for out of your setup? Those questions will help me help you. |
Silver Member Username: Rob315Cuse, NY U.S. Post Number: 487 Registered: Jan-05 | lol...sorry.....they are 2 12" type r's 1242d. looking for a loud daily driver but still able to get loud enough to get into the mid 140's or louder if possible. they will be going into a 1996 ford taurus so space isnt really an issue. |
Bronze Member Username: Audiobass10Cape Coral, FL United States Post Number: 52 Registered: Jul-05 | Peronsally, I'd go with aruond 5 cubes tuned to 35 hz for daily driving. Would get loud too if done right. |
Silver Member Username: Rob315Cuse, NY U.S. Post Number: 491 Registered: Jan-05 | do you have any skill in box building? possibly work out some dimensions for me? |
Bronze Member Username: Audiobass10Cape Coral, FL United States Post Number: 54 Registered: Jul-05 | "do you have any skill in box building? possibly work out some dimensions for me?" I do have experience, but i'm on a new computer and don't have anything downloaded at the moment. My suggestion is to go to www.linearteam.com and download winISD if you dont already have it. Find the Theil Small Parameters of the drivers and plug them into winISD. Should be self explainitory from there. I can't calculate port tuning in my head, so it would be just as easy for you to do it. |
Silver Member Username: Rob315Cuse, NY U.S. Post Number: 494 Registered: Jan-05 | awesome...thanks |
Bronze Member Username: Jb502Omaha, NE Post Number: 71 Registered: Jun-05 | rob fox, check this out http://www.studioonline.com/playclip.asp?iDigitalMediaID=479755&tiEncodingStatus =1&LangID=1&crypt=68C1D53243F9DF13&iMediaTypeID=1 |
