What do youll think of theys subs
Username: Ihaveasystem2
What do youll think of Audiobahn Awc12t 500 watt rms subs??
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8046
not a big audiobahn fan
what's the price for the ones you're looking at getting, per sub?
I can probably find something nicer around the same price.
are you more interested in quality of sound, or in how loud they can get regardless of detail?
Post Number: 7
Pretty da*n loud they say 1000 watts max each but @ 2 ohms I cracked the paint off my roof with 4 of them they sell on ebay for around $50.00 each and also what do you think of a 1000 watt 4 channel Lanzar vibe amp
Post Number: 8
Sorry man I thought you said how loud do they get
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8050
I wouldn't use max power ratings.. stick to RMS, since that's the continuous power they can take without incurring thermal damage.
the audiobahns will get loud, and probably not fall apart on ya, but they aren't known for good sound quality at high output.
generally the louder they get, the worse they tend to sound.
if all ya want is cheap and loud though, they'd serve well
Post Number: 9
well what do you think about the lanzar vibe
