Need a mtx 1501d
Username: Karam
Post Number: 58
hey gus im looking to buy this amp its got good spec. Is any body selling one? and is there any where i can buy it? I think its old now so i can't find it in shops anywhere. im based in uk. if there are any websites could you let me know thanks.
karam
Username: Alias747
MN
Post Number: 382
I take it you never got a hold of that guy in here that was selling one huh? I remember giving you that link. He was selling it for like 285 with shipping if I remember right. That is a GOOD price. Too bad.
Username: Karam
Post Number: 59
yer i tried to contact him TWICE no reply :-(
but im still looking
Username: Zero43
Kyle, TX USA
Post Number: 43
i could find you one for about the same price it wont be new though
Username: Karam
Post Number: 70
ok is that 285 dollars including shipping to uk. and does the amp work.??? what condition is it in?
Water
Get the new rockford amp
Username: Zero43
Kyle, TX USA
Post Number: 45
oh i dont have one i sold mine a few months i was just saying i could get you one. if you arent able to find one ill look around a bit and see what i can find. you should also look into the 81000D they are basicallt the same except i think it doesnt have a compression circuit.
Username: Karam
Post Number: 74
right ok, what effect does a compression circuit have on amps then?
Username: Zero43
Kyle, TX USA
Post Number: 48
its only use is to keep the amp from clipping but it hinders output alot. And actually i just checked on it does have the compression circuit but you can turn it off. Id look futher into it to find what the small insignificant difference is but i dont have the time right now
heres the link http://mtx.com/caraudio/archive/archiveAmps.cfm
Username: Darkseid
Post Number: 89
powerwise its the difference of a few hundred watts. Though as Ron stated it does make quite a difference,and it's def. noticeable imo.
Username: Karam
Post Number: 80
ok, how old are all of these amps? if i buy one of these will they lose there value alot? afterwards could i sell them for good price?
Username: Karam
Post Number: 81
bascially i need some thing to power two subs, they svc 650rms, 4ohm's
i like mtx now, i want one of there amps.
i can either have two amps that will give 650rms each at 4ohm's
or
get one amp that will give 1300rms at 2ohms
Username: Darkseid
Post Number: 91
the 1501d's are from 03 and 81000d 02. Every amp will lose it's value after you've used it.
Username: Zero43
Kyle, TX USA
Post Number: 51
well those two amps may just barely meet the rms power you are looking for but only at 14.4 volts. if you are running a HO alternator it will be fine but even if you dont and you dont clip the amp the life of your subs will be extended.
just look around if you cant find one ill take my chances at it.
Username: Msx
Post Number: 18
www.caraudiosecurity.com Have a big list of amps not too bad of pricing either.
Username: Karam
Post Number: 82
well, you see im based in uk. so i can only look on ebay. The only other places r websites who post worldwide.
Username: Karam
Post Number: 83
lol, just checked out that site, 676 pounds that is 1222 dollars!!! way too much i might even consider used, if there is no mechanical problems with the amp.
