AE Speakers SL-10
Username: Hemiboy
Post Number: 37
I found these on the net and man o man would they be nice for the amount of room I have so I dont have to modify anything. Has anyone ran these yet? Cant find reviews on the net for them. If anyone has the specs please post them. THanks!
Username: Hemiboy
Post Number: 39
Can someone tell me what a passive radiator is and or does?
Username: Hemiboy
Post Number: 41
bump
Username: Geekbike
Post Number: 275
Specs:
http://yellow.mynethost.com/~bv126368/shop/catalog/product_info.php?products_id= 51
Looking at the specs, it doesn't seem like it will get very loud. No slimline subwoofer will get as loud as a standard woofer and they tend to cost more. Looking at your other post, you still don't have enough airspace to house them properly.
Read this for passive radiators:
http://www.diysubwoofers.org/prd/
Username: Hemiboy
Post Number: 42
Ok thanx, I got a really good ideal taht will give me all the airspace I need. I'll post pics when Im done!
Username: Hemiboy
Post Number: 43
Oh, so you would put a passive radiator in the same box with another sub?
Username: Geekbike
Post Number: 281
Well of course. It needs the backwave of the subwoofer to actually move - it has no motor of its own.
