Is the RF T10001BD 1 ohm stable?
Username: Thebus03
Post Number: 7
is that amp 1 ohm stable? And opinions between the Kicker KX1200.1 and the Rockford Fosgate T10001BD? which one is the better buy to power the Solobaric L7 12"? the RF gives 750 RMS while the Kicker gives 600RMS but the RF is also more expensive? what do you all think? anyone used these amps also?
Username: Kd7nfr
Montpelier, ID United States
Post Number: 220
Go for RF. They're underrated a lot this year, and my friend has a 10001BD, and it's pretty good. The L7 is a SPL sub, and the RF is a SPL amp. And yes, the RF will handle 1ohm stable, but you loose SQ that way.
