Audiocontrol
Username: Onthelow
GlassWolf are you familiar with the kenwood 911dvd, it has a seperate component for sound processing. i think its named p901, anyway its to give 5.1 dolby & surround, and adds a 4 band paramic eq to the kvc911dvd. my questions is, could i go with more devices to shape the sound, for example the epic150 0r 160 & audiocontrol eq
Username: Glasswolf
Post Number: 1394
if you want 5.1, the only way to add audiocontrol EQs is by using single channel models like the EQX, or a multichannel model that will only shape the channels which are run through it.
example, an EQL for each pair of channels.
