W7
as far as spl. Is there really that big of a difference between the 13w7 and the 12w7. Well is there enough differnce to pay a extra hundred or two
BabyBrock
having more displacement and more power handling, im sure the 13w7 would have more spl
what im asking is....is it worth the extra money?
Username: Mikechec9
Chicago/atlanta
Post Number: 358
no, imo. then again, i don't think it's worth it to buy a w7 of any size.
Honestly i dont either but i heard one at the car audio shop i went to and it was loud as hell. they guy came back askin how to turn it down cause he couldnt think. It was funny. i want the ame kind of bass in one sub. is there anything out there that will match the W7 almost exactly but cost less?
Username: Big_ed
Post Number: 68
eclipse ti, avalanche
Username: Mikechec9
Chicago/atlanta
Post Number: 360
..re xxx, adire brahma, idmax...
the one 1
but they take more power so figure in cost of another amp and alt
Username: Mike_anthes
Canton, SD USA
Post Number: 110
well a brahma i know doesn't need that much power to get to its full potential...if you gave it a clean 800 watts u would be happy im sure...i looked and the 13w7 needs a little over 1000 and the 12w7 needs about 800...so i think the brahma doesn't need more power than a 13w7 or even a 12w7...and the brahma is much cheaper...get the 15" if ya can...yull be really impressed...
Username: Mikechec9
Chicago/atlanta
Post Number: 371
shoot, i know people pleased with just one 12" brahma. like mike said, the 1600watt rms is just a thermal rating. you can run them pleasantly from 500-100watts, depending on your encloure size.
Username: Mikechec9
Chicago/atlanta
Post Number: 372
woops, 500-1000watts
Canton, SD USA
Post Number: 117
hey mikechec is the xXx the same way...is that a thermal rating...cuz one of my buddy's wants a good sub...if he gave it a good 1000rms would that be enough...cuz he already bought an amp...and his amp puts out 500 rms x 2ch @ 1 ohm...he would have to get the dual 1 ohm voice coil option...thanks
Canton, SD USA
Post Number: 121
bump....
Canton, SD USA
Post Number: 123
bump...
Canton, SD USA
Post Number: 124
ok once again....bump....
