What gauge wire? help meeee
Username: Guifh
Post Number: 11
what gauge wire?
i have a kicker kx1200.1 and a kx650.4...
KMARTXR
i have always used a 4 guage for everything, if the amp wont take a 4 gauge, i attach a gauge that works with a connector. hasnt failed me yet.
the amp should tell you on it, or download an online manual for it
Username: Invain
Michigan United States
Post Number: 2971
For that many total watts, I'd run 2 or 1/0 gauge. Run whichever you chose up to your trunk, or wherever your stuff is gonna be, and then get a distrubuter block, and run the correct size from there to each amp. I'd recommend using the largest size wire that the amps will fit.
